Can't answer all of your questions but I can answer some.
If your oil is too low your alarm will sound so fill it up. The oil system is fed by gravity and not a pressure system like some gas tanks on cars where the pump sends more fuel than the injector pump can handle and then diverts it back to the tank.
Oil drippings is most likely unburned oil. If you can't find answer in the manual, give a call to the dealer to make sure.
