Tips for repairing bottom of Riverhawk?
600 Views 2 Replies 2 Participants Last post by  bourbon
Moved to boatyard basics
1 - 3 of 3 Posts
If the glass is not compromised, You could sand/grind then fill with epoxy, sand the entire bottom and then 3 coats of graphite/epoxy. You could also go with one of the coatings they put on airboat hulls.
Obviously, paint is always an option but it sounds like you’re looking for something tougher.
I haven’t seen a hull bottom done with bedliner material just inside, so I can’t give you any feedback on that. I hear they can put on a smooth finish but it would be more expensive than epoxy/ graphite.
Might want to move this to Boatyard Basics folder, you might get more feedback.
Reactions: 1
Thanks, just moved it.
1 - 3 of 3 Posts
