1 - 3 of 3 Posts
i have a 1998 merc 25 tiller. The tilt is frozen on it. Its a little rusted and wont take grease. Any tricks???? Thanks yall
Here's the diagram for your clamp bracket
http://www.crowleymarine.com/mercury-outboard/parts/3236_170.cfm
You can see that all that holds the tube in place is the end nuts.
Apply penetrating spray to the tube/bracket joints,
let it soak overnight, use a wrench on the end nut
and attempt to rotate the tube and nut. If it fights too hard,
apply more spray and let soak overnight, try again.
Gentle tapping with a wood dowel to the tube may help the spray loosen the rust.
1 - 3 of 3 Posts
