1 - 15 of 15 Posts
I will be removing the center livewell/storage area from the little 13 footer, and I'm opening this for discussion on this forum as it appears the one at CG started by another poster isn't getting a definitive answer.
I've always been told not to remove the center baitwell from a 15 footer, which makes sense as it's connected to the sides with the "wings" and visibly is a structural element to the hull.
On the 13 footer, there are no "wings". The baitwell is attached at the floor only. If you remove the baitwell sides/top and leave the flat floor underneath intact, I can't see it being nearly as bad as doing it on the 15.
I would think it would only add dimensional stability to the hull if the floor underneath the baitwell flexed significantly, but it can't be much, right?
Discussion Starter · #2 ·
Anyone?..........Anyone?
Bueller?........Bueller?
Do I get some sort of reward for stumping even the Google-Master???
:D ;D
What, who, someone call me?
Oh, a structural question...google midship framing...hmmmm.
I like a frame or rib at mid hull to prevent gunnel deflection.
But, if speeds are kept down, and rough water is not encountered,
the buckling of the gunnel is minimized by the aluminum gunnel rail/cap
installed by the builder. That answer your question?
It would be easy to install a frame or two at the midpoint of the hull
to strengthen the cap rail. Useful also as a mounting point
for all sorts of custom add ons. Rod holders, drink holders,
knife holder, camera mount for self portraits...
When building the Slipper I tested the gunnel strength by applying
lateral force to the upper edge of the hull. I reinforced until I was
satisfied with the rigidity of the hull. Can't be too hard to test a 'noe.
Set the empty hull on a pair of sawhorses, add load to the middle of
the hull and watch what happens. If it buckles, add reinforcement.
I was actually contemplating cutting mine out and flooring my 13'. I was going to let you know first hand but havn't had the time to do it.
I would think that it would add some torsional support so I plan on cutting it at what would be the floor level and leave that portion for supporting the floor and minimizing twisting.
That's exactly what I'm looking to do. I would think adding the flat floor should eliminate any issues. I'm not going to be jumping and trawler wakes with it :)
I guess I will be the guinea pig and post the results
thought I would chime in as I just added a false floor to my 15' highsider and didnt really explore the structural or twisting ramifications of removing the center seat.  I made the mistake of removing all the seats cause my highsider was all sorts of f**ked up when I bought it. big mistake- it twisted like a damn banana.  I had to prop it up on sawhorses, strategically add paint cans all over it just to get the twists out.  then I glassed in the floor and added supports for my front and rear deck once it was level.  it sucked, took about 3 hours just to get the damn twists out of the boat and level.  I would definately try to stabilize it somehow or possibly install the floor front and rear of the center baitwell to hold the boats form, then remove the seat and finish it.  just my 2 cents, but I really dont know much about the proper ways of going about it.  I can tell you that the false floor makes it sooo much nicer
ignore my last post... i just noticed that you have the baitwell option that doesnt attach to the gunnels. i say cut away as proposed!- you'll be happy once the floor is finished-more room to move around
Good points. I'm guessing (stress the guessing part) that since the 13 has a free-floating baitwell already built upon a small section of flat floor that the flat floor section would be enough to hold it uniform while I removed the baitwell "box" and fabbed the flat floor.
I should be starting this project in the next 2 weeks so I'll post my findings and of course some pics along the way so Brett has his fix.
Reactions: Donald
Hammer in my hand still pounding on a screw
The first thing I did on my 13 was cut the center seat out. Its just fine and it opens the boat up considerably. Havent really noticed any issues with hull flex. I would also like to put in some sort of floor though this year. It would just be nicer to stand on. Here's some pics of mine.
This has been settled, full story here:
http://www.microskiff.com/cgi-bin/yabb2/YaBB.pl?num=1245982497
I know this is a ridiculously old post, but this link is a deadend now. How did yours turn out? I'm looking at removing my center console from a 15' River Hawk. Same deal, runs parallel to the hull, doesn't attach to sides.
I'm not Tom but It turned out great.
It became a duck hunting machine and we used it to its fullest.
Go for it.
1 - 15 of 15 Posts
