1 - 6 of 6 Posts
not a real good photo But ... This fuel is 1 Week old Premimum fuel , Amsoil , Marine Stabil , and seafoam ... phase Seperation ! Pure alcohol and water mix in bottom of drained fuel !
Soooo Marine Stabil is CRAP !!!
I smell like Gasoline [smiley=angry4.gif] freakin looooovley ! But the Little motor is running once again !
I will try the stuff ron sells and test again ...
I've been seeing a lot of this lately, and on a newer EFI 4-stroke, it can be very expensive repiar, $3-4k is the norm, parts and labor.
Best cure for it, buy it and burn it. Don't store it. If you can't burn it in the boat in a week or two, burn it in the truck.
Also, your gas/oil/stabil/seafom mix might be a little much for an already unstable solution of gas/ethanol. I'd limit it to gas/oil, and use it up.
I had a similar problem a while ago with my lawnmower gas. I had stabil in it and everything was cool, but when I bought a new bottle of sea foam I figured it couldn't hurt and tossed it in as well. I ended up having to chuck the gas cause it varnished up in a week!
My guess is stabil and seafoam react against each other for some reason.
I put Mercury Quickleen and Stabil in every gallon of gas I get. Just about .5 oz of Stabil and a small capful of Quickleen. I haven't had any problems, yet (knock on wood). And my carb is as clean as a whistle.
The world is flat....and shallow.
Thanks for the report. It never ceases to amaze me what this crap (ethanol) does. And we're at their mercy, and they don't care.
Kemo :cool:
1 - 6 of 6 Posts
