So I've had some alone time with the Axiom II X. Had 2 long days on the water and put it to use both casting from the skiff and wading.
First impression is I love the look of the rod. Matches the color scheme.
I set it up with the TFO Power Reel and the new Wulff Bermuda Triangle texture line. This is a super fast setup. I also ran a SA Grand Slam, SA Max Distance and the budget RIO mainstream Saltwater through it. Performed well with all.
This rod is very different than the Axiom II. The only similar feature is in the manufacturing and the fact that they share the same technology for combining Kevlar and Carbon. When you alternate the Axiom II and the II-X in and out of your casting hand they feel nothing alike.
For a competent caster this is an easy 100 ft. rod with every line I mentioned. It is not however a rod that casts itself like the Axiom II.
This rod is very similar in feel to the beast TiCrX rod but much more refined and way lighter in the hand. Like the TiCr this rod is super stiff in the second section. For casters with strong thumb up grips the stiffness in this section instantly converts to line speed and distance.
This was most noticeable when wading. It is always challenging to get 50 to 60 feet of line dragging in the current up into the rod and air. The line speed this rod creates really rips the line up off the water even for a short guy like me.
The beefy mid section also make it easy to drag fish out from under structure. Today we really ran the numbers up on snook. Lots of fish around 24" and we manhandled them with this rod in #8 weight.
I did find this rod to be quite versatile and I plan on adding some additional line weights to my arsenal because of that. Reach casts and aerial mends are no problem and the tip is soft enough to protect tippet.
Based on past my past experience with clients I do not think that this rod is a pick up and go for everyone. As I mentioned this one does not cast itself.
For good casters who have a feel for rod loading and hauling you will love this one. It is pretty effortless to work the 50 to 70 foot range without hauling. With a haul it will go where you need it to and get there fast. If you do a lot of blind casting and throw all day you'll still be able to lift a bobbin and tie a fly after fishing.
If you were fan of the TicrX you will love this rod. If you are not familiar with the ticrX but enjoy fast rods you will also love it.
Price-wise this rod is at the top end of TFO rods but still about 50% the cost of other high technology rods. My opinion is it is worth every cent.
Another big win for TFO
Ken
