Yes, Tohatsu 50, 3 blade prop and what looks like a huge Shaw-wing plate. And I'm sure he runs his own modified intake scoops on the motor.Jack runs a Spear tunnel, right? Tohatsu 50? How is his set up?
I have his custom intake screens on my Tohatsu 50, if you scroll thru this thread earlier I installed them. My Heron has done great for a Non-Tunnel Skiff of course it will always be limited even with the upgrades I have made. But it changed night and day running a cav plate, and heavy cupped prop. The screens Jack makes allow for more water flow lowering your chance of overheating. I personally installed the Trans cavplate because I feel it offer's a better design as a half pipe, keeps water around the prop better.Yes, Tohatsu 50, 3 blade prop and what looks like a huge Shaw-wing plate. And I'm sure he runs his own modified intake scoops on the motor.
I don't know how common it is, but they "say" that if you kick up shell with something like that, there's a chance that instead of throwing the shell clear, it bounces off the plate and back into the prop. Kind of like a disposal lol.While we are sharing cav plates. Here is a fiberglass one I just finished building but haven't installed. My "wing tips" may be a little long but I figured they could be trimmed after some testing. View attachment 127418
A tunnel skiff will always run skinnier, I have been on Eric Glass Chittum (Laguna Madre edition) and you get scared how skinny it can go almost seems like its a fan boat.Soooo.....What would I gain or lose on a small skiff by choosing tunnel or no tunnel if each of them takes advantage of all this magic?
Have had both. My first poling skiff was a 2007 Beavertail tiller, no tunnel but did have a fixed jack plate. That skiff would run in about 9” but took about 15” to get up. I ran that skiff for 9 years. My next skiff was a Spear Glades X tunnel tiller with a 30 etec and micro jacker jack plate. That skiff would run super skinny, 6 inches or less. But even with a good prop it had trouble spinning up on plane with the 30 horse. That skiff would have come alive with a 50.Hoping for some experts to tell me what I'm giving up with a properly set up small tunnel skiff vs no tunnel properly set up in terms of inches and or speed in terms of best guess numbers.
I would disagree with this. I have 3 buddies that put cav plates on their skiffs (EVOx -Shaw wing, Fury - Perma-trim, Fury- Simmons custom rigging plate) and all three said it greatly improved the overall handling and performance. All can run their motors jacked all the way up, all day no overheat issues. All of them said that they have to use very little trim tab as well. I'm putting a Perma-trim on my new EVOx for that very reason, along with a Foreman prop and Foreman intakes.For what it is worth, on my non tunnel Conchfish build I may go with no cav plate, a low water pickup and a custom prop. On a non tunnel I really don't think a plate is doing much when you are running with the jack plate up. It is probably out of the water and not directing anything towards your prop or intakes.
I have run and fished on a Sabine Versatile with tunnel quite a bit. Definitely would improve the performance of the boat if it had a cav plate. The tabs don't push the bow down enough when it is choppy and for a flat bottom boat, you need to get the bow down smooth out the ride. Also, even with a super cupped shallow water angry 4 blade prop on it, it still blows out in tight turns at high jack settings. I get it, it is a flat bottom boat at high jack settings, so we slow down going into turns but that boat would get a huge benefit from a cav plate. They are really cool skiffs.I'm not saying I won't use a cav plate on my build, but I will try it first without one.
Look at Sabine Skiffs. Brian Little is as "mad at shallow water" as anyone and I've never seen a cav plate on any of his skiffs, tunnel or not.
There’s not really an exact rule of thumb for lost draft due to a tunnel. It’s different with each hull and tunnel design because it’s lost displacement. Somewhere, I remember seeing Morejohn post the volume of his tunnel design for the Whipray. It was just a few gallons.
Let’s call it 5 gallons for simplicity. If the volume of a tunnel is 5 gallons, then you’ll lose enough draft to displace that 5 gallons (.67 cubic feet). Across an average skiff hull, I would think that is easily less than 1/2” lost draft. You have to have a model of the hull or Chris Morejohn’s expertise to tell exactly what the tunnel translates to in displacement.
The other way to look at tunnel impacts to displacement is buoyancy. Sticking with our 5-gallon figure for tunnel volume, you would have about the same draft as a non-tunnel skiff if you can lighten your boat by 42 pounds (the weight of 5 gallons of water). Not accounting for distribution of weight and other factors. So a 800lb non-tunnel skiff will draft about the same as a 758lb tunnel skiff with a 5gal tunnel.
I'm late to the party, but in the process of outfitting my new 50 Toe.Game changer
