Synthetic bunk boards
Discussion in 'Boat Yard Basics' started by efi2712micro, Dec 24, 2017.
  1. efi2712micro
    efi2712micro Well-Known Member
    167
    25
    103
    has anyone replaced carpet covered wood beams for synthetic ones like the ultimate bunk boards? See a lot of advantages and cost is not too bad. Seems to make launching easier but would appreciate hearing from anyone who has them. Thanks.
  2. jmrodandgun
    jmrodandgun Well-Known Member
    1,531
    1,039
    718
    These things have been around forever yet I think I've seen one trailer with these cutting board material bunks. HDPE is not very stiff so I don't see it working very well on a lot of trailers.
    It's really really really hard to imagine a boat coming off plastic bunks any easier than property maintained carpeted wood bunks.
  3. richg99
    richg99 1652 G3; Malibu Mini-X kayak
    567
    29
    403
    I did this project on an aluminum boat, but I don't see any reason why it can't be done on any carpeted bunks for any boat. I used 3x4 inch PVC Gutter Downspouts from Lowes. I capped the present carpeted bunks. Cost about $15.00 total plus screws. Because the Downspouts extend down the SIDES of the wooden bunks, fasteners do not touch the bottom of the boat. I used Stainless Steel screws on the first boat, and used aluminum nails on the second boat. The first set is holding up well after two years of use. If they wear out, replacements are cheap enough..https://www.tinboats.net/forum/viewtopic.php?f=3&t=40137&hilit=bunk
  4. Smackdaddy53
    1,945
    1,777
    968
    I honestly would never use anything but carpeted bunks on a glass boat because I think sand would get between the hull and bunks and scratch the gelcoat. I had poly bunks on my last trailer and they scratched the bottom pretty badly.
  5. efi2712micro
    167
    25
    103
    That pretty much settles it for me then ....
  6. Pudldux
    Pudldux Well-Known Member
    76
    26
    93
    Trex decking works awesome. Sand and dirt builds up in the carpeted bunks. All about no maintenance such as replacing carpet or staples etc.
  7. Smackdaddy53
    1,945
    1,777
    968
    No scratches on the gelcoat?
  8. Pudldux
    76
    26
    93
    No scratches here.
    Smackdaddy53 likes this.
  9. DuckNut
    DuckNut Brandon, FL
    4,641
    490
    1,938
    I have synthetic guide boards on my trailer and the vibration has given the boat a severe case of the rash.
    Will take them off and replace with carpet the day after duck season. Never again. Also have to repair the boat now.
  10. Smackdaddy53
    1,945
    1,777
    968
    That sucks. Pretty much what I had going on but mine was an aluminum hull with GatorGlide bottom coating so it was harder to keep still. Carpet just seems to be the best option. If it wasn’t every boat would come on a trailer with synthetic bunks and no carpet on them.
    When I think about non carpeted bunks now I am reminded of sanding blocks.
  11. DuckNut
    DuckNut Brandon, FL
    4,641
    490
    1,938
    That is exactly what they become. Some of the spots that are wore down are pretty deep. Certainly learned my lesson.
  12. Smackdaddy53
    1,945
    1,777
    968
    The ramp I launch at most of the time has a sand parking lot and my vehicle is covered in sugar sand when I get back so no more poly bunks for me. While trailering road grime has to get between the hull and the bunks too. At least carpet will cushion some and not be a hard surface for grit to eat at the hull.
  13. SomaliPirate
    SomaliPirate Well-Known Member
    535
    871
    218
    Carpeted bunks with a little silicone sprayed on them are the way to go.
