Suzuki NMEA 2000 network - DIY?s
Discussion in 'Power it up with Electronics' started by Str8-Six, May 10, 2018.
  1. Str8-Six
    Str8-Six I Love microskiff.com!
    541
    435
    188
    firecat1981 likes this.
  2. jay.bush1434
    jay.bush1434 I Love microskiff.com!
    55
    38
    93
    I don't have any gauges on my Vantage. All of my Zuke engine data reads directly to my HDS7 through the NMEA2000 network cable. I don't know if your analog tach reads data from that same cable connection or if it has its own, connection. If it does read NMEA2000 data, you will only need a T and make the connection to the tach. If it reads separately, then no need to tie them together as the RPM's and a host of other engine info can be displayed on your Lowrance, including engine hours to the 1/10th, and fuel burn.
  3. Str8-Six
    541
    435
    188
    Here is my current tach above.
    Thank you. Pretty sure my tach doesn’t have NMEA compatibility so I ended up buying the adapter cable parts and I’m going to make it myself. I’ll post an update once I get the parts.
