1 - 8 of 8 Posts
I Love Skinny Water
My 140 has always run great. This year after it sitting for months on the fist warm day I cranked it up. It idled fine and with some throttle it ran fine then it started running rough. I notice the fuel hose coupling had a leak and have not checked the water filter for water yet. It seemed to idle ok but not accelerate
I had a 115 Suzuki 2 Stroke ( same block as the 140) a few years back. After it sat for a few months, the fuel started to gel in the carburetor bowls and then migrated into the high-speed jets in the carbs. The engine started and idled ok, but would not accelerate or run at any speed. I ended up pulling the carbs, cleaning the bowls, blowing out the high-speed jets with carb cleaner and reassembling. It was a pain, but it took care of the problem. Good Luck!
If your running only non E fuel, you are way ahead of the game and it's likely not a separation / gelling problem. I think you are on it, like Smack said fix the vacuum leak on the fuel line. If you were using an E fuel, I'd also be looking for deteriorating / collapsing fuel line.
1 - 8 of 8 Posts
