I just picked up a SuperStick anchor and decided to build my own bracket out of 1" UHMW. I didn't take pictures of the build but the base is 1" thick and the section that the pole slides through consist of 3 pieces plus the base. The SuperStick is 3/4" thick and I drilled the hole on the bracket 7/8" with a forsener bit. The bracket is bolted to my trolling motor which is removable. To do it over I would probably mount the bracket to the bow in the case I am poling and leave the trolling motor at home. Next project will be a transom bracket.
