I may have a leak somewhere, but for the life of me I can't find it so thought the collective wisdom at MS could help...
2016 East Cape Vantage (new to me) and had a strong smell of gas. The dealer drained the fuel/water separator into the bilge (it was fuel). I got it all out, wiped it down and the next morning, there was fuel in the bilge. Replaced the filter and no leaks there. Took all (most) of the old gas out and refilled with fresh.
Noticed fuel through the front hatch drain hole and the anchor chain was soaked in fuel. Took the port side speaker out and saw fuel puddled by the fuel cell. Same side as the vent. No idea how that got there.
Got that fuel out, wiped out dry. next day no fuel in bilge but strong fuel smell. Got some Simple Green and hosed down the inside so it drained out- got all three sides wet (three drain holes) and lots of water flushed through. Put a fan in front hatch to blow down inside of boat.
Today, everything dry but still a strong smell of fuel. What's going on?
1. Could be the vent pipe is clogged? How do you remove a flush mounted vent? There is no access to the inside (rod tubes)
2. There is a dinural valve in the vent line... could that be leaking? No sign of fuel leaking though.
3. What else should I check?
Thanks!
Thanks!
