1 - 10 of 10 Posts
Hooking Lips is my life
ok I dont know what you call it but the tube where your steering goes through on the motor. Do you have to grease inside that tube and if so what kind of grease.
http://www.teleflexmarine.com/support-2/faqs-2/mechanical-steering-systems/
We suggest the following periodic maintenance, at least twice a season:
Be certain the helm(s), cable(s), steering wheel and connection hardware are correctly
assembled and in proper working order. Check for signs of stiffness, binding, excessive free play and/or wear.
These items cannot be repaired; if any components are not in good working order, replace them. Disassembly of these items will void the warranty and can lead to steering failure. Always replace steering cables that are stiff in operation or have damage to the plastic jacket (outer casing).
Clean and lubricate the engine tilt tube or cable support tube and the steering cable telescopic
output ram as follows:
a. Remove the steering cable from the tilt tube.
b. Clean the tilt tube inside diameter thoroughly.
c. Remove corrosion in the tilt tube with a wire brush. Wipe until all loose material is removed.
d. Lubricate the tilt tube with a good water resistant grease.
e. Scour the steering cable telescopic ram with a brass wire brush and wipe until clean.
f. Lubricate the sliding parts of the telescopic ram with a high-quality, water resistant grease.
g. Reassemble, making sure all (correct) fasteners are tight and there is no binding or excessive
free play in moving parts.
Note where locking fasteners are used. Do not use non-locking fasteners; vibration can loosen them causing steering failure.
I always installed a Steersman type lubricating nut for added protection.
Cert. Yamaha technician
Steering frozen?
Your going to have to unhook the arm, loosen the big aluminum nut that holds the cable to the threaded steering tube,beat the steering cable out of the steering tube of the motor(depending on boat you may have to pull the motor to do this) with a long extension, brake clean and force rags and wire brushes thru the steering tube (what ever you gotta do to get it clean), clean the steering cable as well, liberally wipe mercury "special 101" all over theering cable and in the tube and re-assemble. If you want to take it a step further, theres a nut that you can buy that screws on to the opposing side of the threaded tube with a grease fitting on it, so you can grease it a little easier lol.
there's a wire brush available,"T&H marine" makes it,it chucks in a drill - run this through the tilt tube,after the cable's out .
those sealed nuts work well - using a good waterproof non mettalic grease is the way to fly-a good lube is corrosion block grease
http://www.learchem.com/products/cb-grease.html
lube the cable,before installing it in the tube...
alot of time,the tilt tube is damaged on the inside,from corrosion,the cause  of the stuck steering.avoid the temptation of heating the tube - there's plastic bushings in there,upon heating,these will be damaged.sometimes,the cable just won't come out,at this point,the cable's cut,and the tube's replaced...
And then, after much frustration from not knowing what is wrong and cranking on the wheel as hard as possible and destroying the helm as well, the owner gives up, calls me, and has a Baystar kit installed..
Fixed it for you
Fixed it for you
ain't that the truth !!!
1 - 10 of 10 Posts
