81 - 88 of 88 Posts
Discussion Starter · #81 ·
Have you weighed it at all yet? I saw you were planning on ~600# hull weight. That seems like a lot for a bare hull. My hull is roughly the same size and 95% of the metal is in place and I couldn't imagine it weighs more than 450# tops.
I haven't weighed it. I'm just going off the specs Nathan gave me. It has a lot of decks and hatches which will increase the weight.
Discussion Starter · #83 ·
is all that oil canning on the gunnels going to lay flat?
Yes I'll be able to fix it pretty easily. I just need to unscrew the top plate and rescrew it, which I had to do anyway to change the type of screws. It's all spec'd out in the plans. It was my mistake. Everywhere that it's oil canning is a spot where I undid the screws to enable it to lay flat on the wooden frame. I should have made the frame and screws on the top plate fit together, and I wouldn't have this minor problem.
81 - 88 of 88 Posts
