1 - 14 of 14 Posts
Adding a poling platform onto my skiff and was thinking of using starboard for the actual top. Has anybody ever done this and had success? I am particularly wondering about what thickness I need. There is a big price different between 1/2 inch and 3/4 inch. Would 1/2 inch do it?
Premium Member
I have one here that is 1/2” but has a support in the center of a 30” length and is just fine.
I wouldn't consider Starboard for a poling platform deck... Instead I'd cut a piece of 1/2" plywood, glass it on both sides, then either paint, gelcoat, or cover it if you want a cushioned surface. If you're not careful, Starboard will crack on you and it's not at all ideal as a stand-alone non skid surface (not to mention what it will cost you before you even start shaping it to fit... ).
Hope this helps... aren't boats fun?
Thanks for the help guys. I think I'll try to glass a piece of plywood because I really don't want to pay for the starboard and seadek. Any suggestion as to using pressure treated or just normal plywood @lemaymiami?
Premium Member
Do not glass PT, it will not bond! Use regular plywood and epoxy
Reactions: mgcolli
Starboard is pricey, and very heavy. You can improvise if you can find a fiberglass hatch off a bigger boat, or just glass your own. Marine plywood, or coosa board would be ideal.
Premium Member
Give me the exact dimensions and I’ll build you a top out of fiberglass for $250 + shipping in white gelcoat. I’ll need to know if it’s a drop on or sit in place top also.
Reactions: not2shabby
Yes, everyone does this. My glass one blew off one day stunningly and called around as I needed one ASAP for a trip. Turns out most of the replacement "lids" as they are called, are starboard.
Premium Member
A lot of fabricators have gone to starboard so they aren’t limited in their designs.
A deck for a poling tower is easy to make and sell, if you work with starboard.. The guy who has to use it day in and day out will find out why I prefer fiberglass (wood reinforced or otherwise...) with the appropriate amount of non-skid on it...
Premium Member
1 - 14 of 14 Posts
