1 - 8 of 8 Posts
I have a 99 Johnson 50hp 2 stroke. When I first got the motor last year I had to replace the computer. I also did the spark plugs and all fluids.
It has run great except for one thing. When I put it into forward gear just above neutral it will stall out after about 45 seconds to a minute. The engine will vibrate some and just die. I need to go slow in the canals in Winter Park. All else is well.
I think maybe I need to clean the carbs? Would this help?
Idle adjustment screw,
either on the shifter (older models)
on the carb on most models.
If you know very little about working on engines,
take it to a reputable outboard mechanic for a tune up.
If you can change a spark plug and follow instructions
then get the OEM Shop manual for your motor.
It'll show you what to do and how to do it.
OEM = Original Equipment Manufacturer
Does it run fine otherwise? Only stalls when at idle in gear, after about 45 seconds? Probably idling too low if so.
On land with the flush muffs attched, I assume it idles just fine? With no backpressure and no engine load it should idle nice and low without stalling, but in the water, well that changes everything!
So I have the manual.seloc. I have looked for idle adjustment and cannot find it. Is there a technical name I should look for? The closest thing I found was the IAC valve but I don't think thata what you are talking about. Any suggestions?
1 - 8 of 8 Posts
