1 - 17 of 17 Posts
I have two speakers in the front bulkhead of my skiff. Wiring is a pain in the butt and I'd rather just have as little of it as possible. When I'm fishing the flats I don't listen to music, and when I'm running my two stroker is so loud I'd barely hear it anyways. I use a bluetooth at the sandbar.
How would I patch these holes? I do want to glass over them but I'm a total newbie to doing any kind of glasswork so I don't even know where to start. I'd rather not use round access hatches or anything.
Any advice is appreciated!
With that damage already done I would use thin starboard pieces with stainless screws to cover the holes and use a little clear silicone to seal.
If that ends up being my best option I'll just pull the wiring but leave the speakers in and seal it up with silicone. I was hoping there would be a way for me to fill and glass it.
Do it right. Do it once.
Sand and bevel the hole edges. Glass, fair, sand, and gelcoat overtop of the holes. If you can get the gelcoat close in color and tint you’d be hard pressed to see the hole repair. Lots of videoes online that can walk you through the repair in detail. Try boatworks today via YouTube, very informative and talks you through the products he uses.
I'll definitely check that channel out, thanks! What will I use to fill that void? From what I've seen, it helps to have access to the back of the hole you're trying to fill (watch it...). Can I fill it with another kind of foam or something? That area is between the bulkhead and the "bucket" storage of the front hatch.
Again lots of options, but something as simple as a cardboard backer can be placed behind the hole if you feel it’s needed. Ultimately, if you bevel the hole as recommended, the glass will lay surprisingly well. Replacing the foam that was likely poured in place would be tough to do cleanly. You could mask the hole off with wax paper and carefully pour two part foam in the top.
Something like "great stuff" is probably not a good option for marine applications, right?
Correct - you're better off using styrofoam blocks than great stuff - just be sure to test whichever resin system you choose with whichever foam back you end up using (some resins will melt some foams) - the "blue stuff" at the box store IS compatible with most epoxies
Discussion Starter · #9 ·
Excellent, thanks. Last question - what's the most economical option you'd still recommend as far as resin/fiberglass for small repairs like this? I only have one other glass repair to do (see my other thread in BYB) so buying in a larger quantity doesn't make sense.
You can buy a access cover that would screw right over that.
If you glass it make a backer out of glass on a plastic bag and then epoxy it to the inside and then repair from the outside.
The kit @yobata shows would work, you might need two.
When you send me your address for your other thread, I will throw some glass in there for you as well. You will just need resin and putty.
Discussion Starter · #14 ·
@DuckNut You're the man. Thanks! I'll PM you my address and the dimensions tonight.
@Boatbrains Is there anything Big Brother doesn't ruin?
1 - 17 of 17 Posts
