Sounds a bit far fetched
Discussion in 'Off Topic' started by noeettica, Jul 4, 2011.
  1. noeettica
    noeettica Well-Known Member
    3,734
    139
    2,268
    Jet ski thrust causes "severe" injuries ... Really ?
    http://www.baynews9.com/article/news/2011/july/273227/Woman-suffers-serious-internal-injuries-from-thrust-of-personal-watercrafts-propulsion
  2. sr5boy
    sr5boy You Know
    64
    the new skis have a warning sticker for this. Sounds like an extreme saline enema. :eek:
  3. Gramps
    Gramps Living & Dying in 3/4 Time
    2,558
    31
    903
    I've had the um, privilege of learning first hand how strong the thrust of a 550 stand-up jet ski is. It HURTS when you are laying on your stomach, hit the throttle and you're hit with a 3" jet stream. It's been known to blow off bathing suits! I always forget to tell the girls about that... ;D
  4. topnative2
    topnative2 Well-Known Member
    2,515
    806
    968
    NOT--It does happen ---- when done in a hospital it is called an episiotomy which is a procedure used to make it easier for the gal to deliver --- it involves making a incision from the ********* to the *********.
    Now imagine a high pressure water stream doing it
    even occurs when  one is fully covered
    be careful out there
  5. iMacattack
    iMacattack busy, too busy
    4,697
    246
    2,268
    [movedhere] General Discussion [move by] iMacattack.
