1 - 13 of 13 Posts
$19.5k
2017 Prodigy 1651 with V Rake
  • Mud Buddy HD Black Death 4400 with 84 hrs
  • Q muffler
  • 42 mm Mikuni carb (non ethanol used exclusively).
  • Forward, neutral, momentary. No reverse.
  • Fresh service, new air filter, oil filter, carb rebuild kit, spark plugs, fuel filter, greased zerks
  • Stored inside garage at all times
  • 21 inch sides
  • Prodigy side crimp
  • Prodigy chine
  • Removable grab bar
  • Dual rain Plugs
  • Rear Battery Tray
  • 18" Rear Drop Deck
  • Deck Hatch
  • Drop Deck handles
  • 4 Foot Front Deck
  • Gun Box (holds 4 52” shotguns in cases)
  • Trolling Motor Bracket / Battery tray is also included -- battery box mounted on right side up against front deck, run wires thru wall under catwalk.
  • Front Bow Rails
  • Half Box on starboard side with seat base
  • Spotlight Bar - Timber 124040
  • Fuel Tank - 10 gallon permanent tank w/ gauge
  • Spud Pole Holes - front and rear holes
  • Full Floors with recessed floor bracing. This option makes the floor flat.
  • Side Catwalks 8 inch
  • Rear Catwalks 8 Inch
  • Catwalk Tray
  • Cup Holder - 2 in right side catwalk
  • HydroTurf
  • Black Grass - Green Camo Boat and Motor
  • Switch Panel - 6 switches
  • Shark Eyes navigation lights
  • Bilge - 1100 GPH Bilge pump
  • Plug 12 Volt - Accessory 2 12 Volt Plug -one on switch panel and one plug in catwalk face on front right side.
  • Plug Trolling Motor 1 Trolling Motor Plug (Twist Lock male and female provided) with 50AMP Circuit Breaker
  • LED Interior Lighting - GREEN - inside all hatches and inside cockpit
  • Water Fuel Separator
  • Brand new spare Big Blade prop
  • Spare throttle cable and fuel hose
  • 2 millennium marine seats and bases
  • Beavertail boat blind. No drill, quick on/off. Karma wetland pattern 1600 Series Boat Blind - Explore Beavertail
  • Gator Glide
  • Magic Tilt Galvanized Trailer with removable tongue and spare tire (fits inside 20’ garage)
  • Two spare trailer hub kits
  • Pre Wired for Simrad with ram ball mount near grab bar
The boat runs great and no issues except for the fuel gauge stopped working. I use a wooden dowel dipstick to measure fuel. Hunts 3 comfortably. Runs about 30 mph with two guys and gear.
Text is easiest and I can send as many photos as you’d like. Boat is located in San Antonio, TX.
Water Cloud Sky Boat Watercraft
Wheel Tire Sky Building Cloud
Automotive tire Bumper Font Gas Drink
Green Rectangle Gas Wood Machine
Green Vegetation Motor vehicle Urban design Wood
Wood Road surface Rectangle Asphalt Shade
Green Building Road surface Asphalt Grass
Automotive tire Tire Motor vehicle Wheel Bumper
Automotive tire Bicycle tire Motor vehicle Track Railway
Motor vehicle Automotive tire Automotive design Machine Toy
I had a 1854 w/ a BD4500. Drove the shit out of that boat. GLWS!
I Love Skinny Water
Man of I had that I'd probably hurt myself. That camo is...rad
Congratulations man ive sold several so i know how good that feels 👍 whats in your plans for future flotation 😁👍😎
1 - 13 of 13 Posts
