SOLD/EXPIRED (SOLD)Minn kota 50#/birdsall TM mount/ RAM stabili
Discussion in 'Sold/Expired Classifieds' started by zero_gravity, Feb 3, 2009.
  1. zero_gravity
    zero_gravity Well-Known Member
    176
    I have had this trolling motor about 18 months
    It weighs approximately 20 pounds
    It has a few scratches other then that it runs great
    MINN KOTA RIPTIDE
    12VOLT RT/50/SC/S
    TILT TILLER
    42” SHAFT
    I have the original box which can fit all three items
    The trolling motor bracket comes in around 5 pounds
    The stabilizer comes in around 2 pounds
    I’m in Miami zip code 33155
    The box is 54 inches long 18 inches wide and 8 inches deep
    Deck Mount Trolling Motor Bracket
    Birdsall’s Trolling Motor bracket simplifies the mounting of your trolling motor. The removable deck plate mounts to any flat deck area with a permanent 3/8” x 5 1/2” diameter deck plate. The removable mount then bolts to the deck plate. The unit is constructed of marine grade aluminum. It is available in anodized black or clear. The motor mounting area is black high density plastic. This Birdsall product will give years of trouble free service. Mount, Including deck plate. Note Trolling Motor bracket intended for electric motors only.
    RAM® Trolling Motor Stabilizer
    Protect your bow- or stern-mount trolling motor from bouncing while running in rough water or trailering your boat. The RAM® Arm mounts at any angle and holds the motor shaft secure, preventing the motor head from hitting the deck and causing damage. Simply loosen the knob in seconds and put the motor in the water when it's time to fish. Complete system includes base, arm and clamp base.
    Fits any Minn Kota or MotorGuide motor.
    Tall (11") . shipping is not included
    all for $300 located in miami
    eric 305 968-9864 anytime
    _________________
  2. JIMMYZ750
    JIMMYZ750 Well-Known Member
    232
    Re: Minn kota 50#/birdsall TM mount/ RAM stabilizer
  3. zero_gravity
    176
    sold thx for all the interest
