SOLD/EXPIRED (SOLD) Bennett Trim Tabs (New)
Discussion in 'Sold/Expired Classifieds' started by Weedy, Jan 8, 2009.
  1. Weedy
    Weedy Well-Known Member
    817
    1
    393
    One set of the 12' x 9" Bennett trim tabs still in the box. I was going to use them on my mako, but quite that project! Everything is in the box, will get pics if needed! THis kit comes with the standard "Rocker Switch", not the "Joy stick"(junk!). I would like to get $425.00 plus shipping.
    Thanks
    Walt
    Bennetts Web site:
    http://www.bennetttrimtabs.com/trimtabkits.php?cID=1
  2. Weedy
    817
    1
    393
    Re: Bennett Trim Tabs (New)
    So one buy these things, I want them out of my garage!
  3. snooknreds2
    snooknreds2 Well-Known Member
    558
    weedy is this the complete set up? I need just the metal "tab" as I have three of the pumps and all the wiring and hydraulic pistons to go along with it. Just dont have the tab part its self. I do have a question about the wiring harness that I have though. on the clip that goes from the harness tot he motor there are several wires, four I believe. I know that the green and blue are for raising and lowering the tab but there is a red power "looking" wire that does not have a mate on the receiving plug for the wiring harness that is on the pump side. Is yours the same way?
  4. Weedy
    817
    1
    393
    Both the harness from the console and on the pump have 4 wires in the plug.
    Break down:
    Red-Port Valve
    Green- Starboard Valve
    Blue-Motor Forward (pump pressure)
    Yellow-Motor Reverse (pump pressure)
    This is a comple kit, you can buy just the tabs from Bennet I believe or go to the Dania Natical Flea market coming up and I'm sure you will find a least one set of tabs there.
    PS, Price dropped to $375.00, I want these out of my garage.
  5. Weedy
    817
    1
    393
    SOLD!
