1 - 10 of 10 Posts
2008  SeaArk Tunnel Hull Jon Boat
This boat has been completely Customized By shallow water customs.This is an all welded hull that is 16’ long and has an extra wide 6’ beam.It is extremely stable and floats in approximately 4” of water.This is the ultimate shallow water micro skiff. When you combine the hydraulic jack plate with the tunnel hull you can jump on a plane and run in super skinny water.This Boat is only 5 months old and is in NEW condition. Yamaha 50 hp engine tiller steering, electric start and power trim & tilt,  Forward casting platform with seadek, rear polling platform with seadek.Custom seadek throughout the entire boat.Signature marine horizontal rod holders(can carry 6 spin or plug rods and 2 fly rods)12 gal fuel tank, CMC hydraulic jackplate (PL-65), Custom power tech 4 blade s/s prop with extra cupping.Small light weight AGM battery,  Wang shallow water anchor with transom mount, push pole holders, Rocket trailer with breakaway tongue, Carbon Fiber extension tiller handle (Tiller Pillar), Bob’s machine aluminum dolphin stabilizer plate.Over 14 K invested.This is the ultimate shallow water micro skiff. Won’t last long. Serious inquiries only $10,500.
call Danny at ( 305 )338-5965    additional pics available upon request.
Curmudgeon Emeritus
1996 Scout 192 Sportfish
Re: 2008 16' TUNNEL HULL MICRO SKIFF
WOW that's trick!
Cheers
Capt. Jan
i have fished on this skiff and let me tell you i have never been on anything that that runs this shallow. its almost like beign in a air boat. we also won a redfish tournament at flamingo on this thing its second time out. it will go were no other skiff can go.
Discussion Starter #7
Re: 2008 16' TUNNEL HULL MICRO SKIFF " PRICE REDUCED
This boat has been completely Customized By shallow water customs.This is an all welded hull that is 16’ long and has an extra wide 6’ beam.It is extremely stable and floats in approximately 4” of water.This is the ultimate shallow water micro skiff. When you combine the hydraulic jack plate with the tunnel hull you can jump on a plane and run in super skinny water.This Boat is only 5 months old and is in NEW condition. Yamaha 50 hp engine tiller steering, electric start and power trim & tilt,  Forward casting platform with seadek, rear polling platform with seadek.Custom seadek throughout the entire boat.Signature marine horizontal rod holders(can carry 6 spin or plug rods and 2 fly rods)12 gal fuel tank, CMC hydraulic jackplate (PL-65), Custom power tech 4 blade s/s prop with extra cupping.Small light weight AGM battery,  Wang shallow water anchor with transom mount, push pole holders, Rocket trailer with breakaway tongue, Carbon Fiber extension tiller handle (Tiller Pillar), Bob’s machine aluminum dolphin stabilizer plate.Over 14 K invested.This is the ultimate shallow water micro skiff. Won’t last long. Serious inquiries only $9,500.
1 - 10 of 10 Posts
