Snake Oil ?
2551 14
Bought a bottle of Sentry Gasoline Plus anyone test this yet ?
Or am I the first ?
1 - 15 of 15 Posts
I bought mine from the Nose Bleed Guy Paid 3 bucks too much ... But it can be had for around 10 Bucks for 8 ounces ...
Unleaded Race fuel is about 8 bucks a gallon ...
dave
Sentry FLUNKS ! 5.5 GX Honda Kept under Cover Ambiant Humidity .... Water seperated out of gas !!! about 2 weeks !!!
The Marine Guy said " This Stuff makes water Burn " Ahhhh [smiley=bs.gif] [smiley=spank.gif]
Drained Sump and Bowl added 1/2 Ounce of sentry to tank ... NO Inprovement !!! SNAKE OIL!!!
Back to Square One :-(
theres gotta be something more to the story about your fuel, I've had mine sitting around for 3 months with no issues and no stabilizer, just oil. did you drain the tank and it happened again? or are you trying to repair crap fuel?
Drained the Fuel ... New Fuel ..."new fuel"only 2 weeks old was treated with sentry ..will work more on it tomorrow ...
After that I'm buying Avgas and adding TCP
if it is outside maybe theres a crack in the tank thats letting water leak in or something? or a bad seal on a fitting, cause there is no way problems like this would arise from the fuel after just 2 weeks, if so then everyone would have broken down boats in there yards.
X2,
Do you put the cap on the tank. Have you piss some one off that may be adding water to your tank???
Discussion Starter · #14 ·
latest info Sentry seems to work the best of the three The motor almost runs on what seperates out ... And not as much seperates out ... And after You Drain the 3 ounces from 1.5 gallons The motor will run on half choke or no choke at half load ... 5.5 Gx Honda ... Gas less than 3 Days old Runs like New ....
Dave
The Boat which the tank is 100% sealed is fairing much better except except the expansion and contraction on the seald tank is scairy ...
1 - 15 of 15 Posts
