1 - 19 of 19 Posts
devilray snob
Whats the smallest and lightest (size as in dimensions, and weight) battery that can be used to start an outboard which has electric start? It would be used on a 15HP merc.
I'm thinking one of those small/half size odyssey batteries? But I dont know what rating would be the smallest. Weight is a concern too...dont want to shove a deep cycle trolling battery back there.
Stripper in my own Mind!
A small Odyssey should be perfect for a 15. They are sealed and very lightweight. I use one and it powers my Lenco tabs and electric jack plate plus nav and led lights. I don't have electric start or charge on my motor and it has never been drained in a single session. Here's the one I use:
http://www.amazon.com/gp/aw/d/B0002ILK6I/ref=mp_s_a_1?qid=1352082070&sr=8-1&pi=SL75
Good price too. Mine was from 07 and I just replaced it a month ago. Bought mine from Batteries plus and payed about $50 more...
Curmudgeon Emeritus
1996 Scout 192 Sportfish
Get the CCA (Cold Cranking Amp) specification from your outboard manufacture for the engine you have and match a battery to it. The "smallest" may not be the best. Yamaha for example requires more amps than some other outboards. You will end up frying the battery.
Capt. Jan
Odyssey 625, weighs in at a stealth 12lbs. Used for electric start, tilt, bilge on 20hp Tohatsu and never once taken it down to less than a need for a minimal "pop" recharge(using Odyssey charger about 10 mins.). Pricey but well worth it. They use these batteries in Alaska to start up airplanes in -50 degree weather so they can be depended on!
Just a thought, my flouder gigging boat I run the ele. start off my trolling motor battery, it's a group 27 and I have never ran it down where it would not crank my engine. Also I assume your 15hp has a pull rope so if it did you have a back up.
Not sure if you have a trolling motor but if you did you could kill 2 birds with one stone.
devilray snob
Discussion Starter #7
I do not have a TM, I and specifically trying not to use a TM battery because they are so hefty.
I use an Odyssey 925 as the starting battery for my Yamaha 2stroke 90 so I would assume that you would be more than ok using the 680 which is the next step down.
My AGM battery died at the ramp one morning. Hit the Walmart and bought a $25 mower battery to get me by that day (elec start Yami 15 has no pull rope without disassembly). 275 cca. Weighs 14.8 lbs. Almost 5 years later, it's still in the boat. :)
Elec start and trim tabs are no problem.
devilray snob
Discussion Starter #11
The 625 would have been sufficient, but I went with the 680 in case I want to add an automatic bilge later on.
Does anyone know if these can be charged back up with a standard deep cycle charger?
I ended up buying a new charger that had the Agm mode along with others. It is still pretty cheap from Walmart. Just remember to allow plenty of time for a trickle slow charge and you will be fine. A standard would work also as long as you do not give it too many amps. Main thing with these batteries, do not use high charge setting and avoid a complete discharge. Follow those steps and you should get 3-5 years maybe more out of it..
devilray snob
Discussion Starter #13
I have this one http://www.westmarine.com/webapp/wcs/stores/servlet/ProductDisplay?productId=29106&catalogId=10001&langId=-1&storeId=11151&storeNum=50523&subdeptNum=50529&classNum=50534#.UKJmZOOe9mg
I have the original small AGM Dekka battery which starts my motor and runs the navigation lights, cockpit lights and bilge. I have never charged it outside of my outboard.
I also would not buy an auto bilge vs. a manual one.
Honestly, it looks like your charger puts out a constant 6 amp charge which would not be considered a "trickle charge." After speaking with a guy at Batts Plus, he highly suggested using either a charger that has an AGM mode or something that would charge very slowly at a low amperage like 2 or at the highest 4 amps. Yours will probably work but in order to get the longest life out of the battery, I would look at Wal Mart. I bought the Schumacher and it was around $40 or less... Better to be safe than sorry and it has all the settings for AGM, deep cycle, etc....
devilray snob
Discussion Starter #16
This website here lists it as an 'agm' http://dbcmarine.webstorepowered.com/Guest-Portable-Battery-Charger-12-Volt/dp/B000NI38EE
Matthew 4:19
http://www.amazon.com/PERFORMANCE-12-CELL-MOTORCYCLE-BATTERY/dp/B005KLOYHE/ref=sr_1_1?ie=UTF8&qid=1355193242&sr=8-1&keywords=BALLISTIC+PERFORMANCE+LITHIUM+EVO2+12V+12+CELL
I have this and will share some results soon.
devilray snob
Discussion Starter #18
You get your boat yet?
Same here, Walmart lawn tractor battery, except it was for my 115. Worked great and lasted for 4 or 5 years.
1 - 19 of 19 Posts
