First time poster but have done a lot of lurking.
I’m currently removing the deck and stringers/foam from an old 14 foot stumpknocker. I plan to totally rebuild the stringer and the floor, along with removing original storage hatches and replace with a back deck and front deck to serve as casting platforms and additional storage. I’ve done a lot of thought about materials and Final design but more hung up on materials. I have experience with poly And Epoxy resin and some fiberglass work from shaping surfboards but no experience with boat construction.
Pretty dead set on working with Epoxy resin. I was debating between different corn materials But I am leaning towards Okume Half inch ply for the deck, as far as glassing schedule goes I’ve read a lot of people using anything from multiple layers of 6 ounce, all the way up to 17 ounce Biax. When glassing in the stringers keeping in mind that this is going to be my inshore creeks and flats boat what glassing schedule would you recommend? I was thinking about cementing The stringer to the hull with Thickened epoxy Then layover two layers of 10oz biax with the top layer extending a few inches pass the shorter one. Is this schedule too lite/ or to heavy? What glass schedule would you/have you used on similar size and function boats.
Regarding materials I’ve looked out west system, system 3 and a few other Epoxy brands but I’m not decided on one. Granted this project is going to take me into fall and winter in north east fl, i’ll be working in anything between 50 and mid 70° weather But I plan on glassing around days where the nightly low stays above 60. I’m trying to find a cost-effective Resin with a medium to low viscosity for ease of application and a bonus would be a medium speed Hardner(most are just slow and fast) also would I actually need to go with a fast hardener on a 65 degree day.
Using the half inch marine okume ply what glassing schedule would you recommend for the deck and casting decks. I was originally thinking two layers 10 ounce biax just like the stringer and for the underside possibly going with a few good layers of epoxy to seal around bottom and edges, how would y’all do it? I thought I could get away without bottom glass because I don’t plan on putting any screw holes in the deck, was planning on using Thickened epoxy to bond of the deck to the stringers.
What glass weight would you recommend?
What epoxy company/harder speed?
In addition, I’m contemplating using foam core like divinycell or pvc foam For the aft and rear deck, would the weight being saved by a composite Be that significant? Also how do composite foams span gaps with load? Do they need more/less or equal bracing
