1 - 9 of 9 Posts
Recently put a new 12v Riptide on my HB Guide and the 54" shaft length seems a bit long. Thinking I can remove the head, cut around the shaft while avoiding the wires and then re-attach.
Has anyone done this?
Zephyr Cove is on FIRE!
It can be done but you’ll void any warranty you had so you may as well pull the wires out, cut it and run the wires back to the head with new ends.
Is it worth it to have a shorter shaft? Like the women say “better to have it and not need it than need it and not have it”.
Yes - but will void a Minn Kota warranty if you do it yourself. If you take it to your local service center and have them do it, it won't. Chopped 10" out of my 54" shaft. One of best things I did on my skiff. If you do it yourself, sleeve inside the shaft with something to prevent cutting wires or cut real slow and carefully. That is the only trick to doing it yourself. Don't cut the wires!
I think between 60 and 100 bucks is what they charge. My friend just did his. He bought his from the local service center in Ft Myers and they cut it for free. 54" is way long for a poling skiff in my opinion. Another friend just bought one and left it 54". It hangs off the boat and sticks up way too high when deployed in shallow water.
Yeah, since I mounted mine offset, it’s the sticking up part that gets me. We were setup beachside the other day in waves big enough to come over the front on occasion and I still had 12+” of shaft to lower. It only cavitated a couple times and I don’t plan to fish like that often!
I've done it myself on two different Minn Kota's. It works well and I really like getting rid of the extra (un-needed length). I wasn't aware that the local service center would do this job. If your local service center can do it, I'd pay them for the work. No need voiding the warranty just to save a few bucks.
Called my local service center. He said they had maybe shortened 2 shafts in the past and didn’t know if them doing so for me would void the warranty or not. However, he did estimate it would take 1 to 1.5 hr to do the shortening and their shop rate is $120 an hour.
I’m going to call MK for verification, but either way I’m not sure I can bring myself to write a check for what seems like an excessive amount for a simple task! Especially knowing I can do it myself.
1 - 9 of 9 Posts
