Does anyone have any experience with the Scott Wave vs. the Sector?? Specifically, the 6 wt. I have had a 6 wt. Sector in the past. I liked but it did not feel like a 6 wt. I expect a 6 wt. to feel very light in the hand. When I had the Sector, it felt more like a light 8 wt. to me which is not what I want for that kind of application.
Best 6 wt's I've thrown...
Lamson SS
Orvis Helios 2
Clutch Archipelago
Allen Icon 2
Thanks!
In your 6wt quest only (I'm sure it's your quest for your perfect 6wt)....
You list of 6wts you casted...
Lamson SS - Meh - somewhat stiff for a 6wt, but "ok."
Orvis Helios 2 - The best in your list.
Clutch Archipelago - Broom stick, not what I'd call having much fun casting.
Allen Icon 2 - They are trying, but it hasn't clicked for Allen yet.
Replies above....
Scott Tidal 6wt - Heavier butt section (good for lifting and short shots) but softer mid and tip, so not super light in the swing - I think the best of the Tidals is it in a 9-10wt which it becoming stiffer mimics being slightly faster in those weights.
Hardy Zephyrus and Zane Pro 6wt. Same dynamics as the Tidal above, but lighter and slightly faster with more feed back during the cast and quicker rod recovery in the mid and tip, so less bounce. Still, both of these rods in the 6-8wts are just Ok for me, (except in the 1pcs 8wts). But both of these rods shine from 9-11wts. Same deal, as they go up in rod weights, they get continually stiff and then that causes them to have a faster feel to help carry that heavier line and then those rods come alive with casting power. Same deal with the T&T Exocetts.
Depending on what you are looking for and your budget...
For distance beach fishing and light open flats...
For a budget,...
TFO Axiom 2X in a 6wt.
The new Orvis Recon
Oldies but goodies.... May find a used one
BVK 6wt
Redington NTi 6wt (Pre-FarBanks good luck finding one)
Redington DFR 6wt (Pre-FarBanks good luck finding one)
Loomis GLX classic 6wt
Orvis Helios & H2
For more dough from the piggy bank, try these out...
Douglas Sky
Sage Method (used, pre-igniter, but slightly softer).
Scott Meridian (tho a little softer in the 6wts)
Clutch Core (their cheapest rod, but actually bends like a fly rod, instead of a straight piece of steel rod). Still, bottom of the list here).
Loomis IMX Pro (Not bad in a 6wt).
Have you tried the Orvis H2D?
Sage Maverick Has a more flex feel to the rod that ultra fast rods like the Igniter.
Of course, for the expensive ones... well, there are some but Yikes... $$$
It might be that you are looking for something that is fast but more of a progress bend to the rod and helps you to feel what's going on and also causes it to take less effort to cast with normal mid ranges (not super far and not super close).
Also remember to try other lines from your fav Monic (1 line wt heavier than stated) and going with a true to weight 6wt line. Also amping up the quality of your line can make all the difference and trying to only use flies that are actually sized and weighted to a 6wt line. SA Amp Infinity Salt, SA Amp Saltwater or redfish, Cortland Liquid Crystal or throw a 5wt Monic or Rio, since both of those are 1 line size heavier than stated. Sure, if you have a super fast rod like the Igniter, than the 6wt Rio, Monic or Wulff will help it to bend deeper down in the blank, but then again, it'll be like throwing a 7wt (get it?).
Be careful of throwing lead eyes, bushy bodies, wind resistant bodies, heavy hooks and lots of epoxy on the head, all of which can change how your fly line handles it, as well as tight loops being able to throw them without it tailing during the cast. Sticking with bead chain eyes (if needed), smaller epoxy 3D eyes and smaller scaled down sized flies, tied on #6-#4 size hooks helps.
No doubt, I have a fondness for a good 6wt, which is actually my most fav rod to throw where ever, whenever possible, because when your casting is spot on (that's another story), takes very little effort to throw.
Ted
