School me on the old Beavertail models
Discussion in 'General Discussion' started by Str8-Six, May 16, 2018.
  1. Str8-Six
    Str8-Six I Love microskiff.com!
    541
    435
    188
    Any current models based off of the old ones? If so what’s the difference? Any reason why they stopped making them?
    The ones I’ve heard of are the:
    BTX
    BTV
    BT2
    BT3
    Osprey
    Fishshoot likes this.
  2. Fishshoot
    Fishshoot Well-Known Member
    123
    122
    68
    I believe some of these hulls were the ones involved in the lawsuit between beavertail and hells bay.
  3. 7WT
    7WT Well-Known Member
    40
    19
    83
    The B2 was the Hells Bay Waterman mold. However I understand the real story is that one of the multiple times Hells Bay went bankrupt the original Beavertail owners were able to legally pick up the mold(s) B2, BTX and Osprey. They held onto the B2/Waterman. Eventually Hells Bay made a settlement with Fisher Beavertail after first developing a suit (all lawyers can do it) but it was Hells Bay who paid Beavertail. Beavertail to my knowledge did nothing wrong. People say using the mold is wrong but it appears knock offs happen all the time and in this case Beavertail came by the mold(s) legally. Hey what the heck -Hells Bay under new ownership bought back the mold by paying Beavertail not to use it anymore. FYI that is the original Minnesota based Beavertail and no relation to the current Beavertail ownership who bought the Minnesota company.
    Fritz, Rick hambric and Str8-Six like this.
  4. Str8-Six
    541
    435
    188
    Interesting. So what’s the difference between B2, BTX and osprey? Any others come from HB molds or just B2?
  5. Sublime
    Sublime Well-Known Member
    563
    475
    188
    I had a 2007 Bare Bones (B2 model) . The BTX came later and was a straight transom and different cap. The Osprey I believe was still the B2 but in center console and available with a tunnel. Great hulls all of them.
    Fritz and Str8-Six like this.
  6. 7WT
    40
    19
    83
    I have a 2007 B2 and it is an excellent skiff very easy to pole rides well great draft probably a true 6" maybe 5". Can get a little wet at times running depending on conditions and the sponson hatches will take on some water but I improved latches and very little. I have a merc 60 four stroke on mine which is more than enough. Great hole shot runs very skinny without a jackplate
    Str8-Six likes this.
  7. GullsGoneWild
    GullsGoneWild I Love microskiff.com!
    484
    396
    198
    Some, if not all, of the B2s had/have issues with the stern wake rolling over the transom and filling the crustacean well when coming off plane. I don't believe any of the waterman's had that issue.
  8. 7WT
    40
    19
    83
    I guess that might depend on motor weight and other weight at rear. Exact same mold as far as skiff is concerned.
  9. jay.bush1434
    jay.bush1434 I Love microskiff.com!
    55
    38
    93
    The story I got from Tom Gordon years back was that Beavertail splashed the hull of the Waterman to make the B1 skiff. They found out in an interesting way. A shop in or around Titusville was working on a skiff for a customer that looked a lot like at Waterman but wasn't a HB boat. The shop called HB to come have a look. I don't remember if Tom said he went over there but someone from Hells Bay did and was able to confirm it was splashed and not just a really close copy. There was a defect in the hull mold of the original Waterman mold that caused a little blemish in the finish on the bottom. This mystery skiff, Beavertail B1, had that same blemish in the bottom of the hull. Hells Bay sued and won. They were required to cut up their splashed hull mold per court order. Hells Bay rep was onsite to see the mold destroyed. The B2 was the evolution with enough required changes to differentiate it from the Waterman. I fished one for a couple years. It sat low in the water in the back and was a lot more tippy than I thought it should be. At least it didn't eat up the chop very well and rode rough. That being said, I did get to introduce my son to sight casting for redfish on the flats on it so there is token sentimental appreciation.
    dgt2012 likes this.
  10. coconutgroves
    coconutgroves Well-Known Member
    1,387
    837
    718
    Any boat can have this happen - even wakeboard boats can have water come over the stern. The key is not to stop too quickly - gradually slow down and let the wake dissipate, then back down completely. That's standard boating practice, IMO. I don't have any issues with what you explained, but I do what I explained every time.
    Sublime and Fishshoot like this.
  11. coconutgroves
    1,387
    837
    718
    I believe you are bit off in your hulls. The B2 is a copy of the Waterman through and though. The BTX and Osprey started to differentiate themselves.
    And Beavertail did nothing wrong at the time - HB went bankrupt and one of the best hull designs was not going to be made. They settled and everyone is happy now.
    Fritz likes this.
  12. Str8-Six
    541
    435
    188
    Are BTV, BT3 and Vengeance same hull? No one has mentioned them yet so I assume they are not splashed?
  13. jay.bush1434
    55
    38
    93
    I might be. This was 12-ish years ago but I'm just repeating what Tom Gordon told me. At the time, he had an obvious bias towards Hells Bay...
  14. Sublime
    563
    475
    188
    When I had my B2 a friend brought his Gordon Waterman over and we parked them next to each other. I can say his cockpit was noticeably deeper and his hull had more freeboard. I have a BT DVD somewhere with Mark Fisher explaining that they reduced the freeboard on the B2.
    I had read somewhere way back when that the hull was a Whipray with sponsons added.
  15. EvanHammer
    EvanHammer I Love microskiff.com!
    178
    140
    118
    I'm not interested in debating whether they splashed the hull, but if you think they splash a patented hull they did do something wrong. Even if Hell's Bay was in bankruptcy someone still owned the molds/design - either the creditors, the new owners, etc. Still can't splash someone's hull, even if they aren't currently being built.
  16. 7WT
    40
    19
    83
    The real issue was the purchase of Hells Bay by Brian Broderick. This guy was involved in all sorts of fraud and corruption scams in Alabama prior to purchasing HB from Hal Chittum. He escaped those state charges, not all, apparently by working with prosecutors going after bigger fish. Its too bad HB was sold to this guy. He ran it most likely purposely into the ground taking 28 deposits over $400k and not building as well as taking out large loans over 2.5m which he was called in on and that lead to the bankruptcy. Chris Peterson is quite the guy to pull it all back together including merging with Gorgon boatworks which had acquired rights to two of the Waterman molds. And then Peterson also cleared up Beavertail's mold which it isn't too hard to perceive that Broderick made some deal on with Beravertail. Chris Peterson did "save the day" for Hells Bay and that's great and the dog was Broderick and the choice of selling HB to him.
    flysalt060 likes this.
  17. coconutgroves
    1,387
    837
    718
    Aw lawd... here we go....
    Hulls have been splashed since the dawn of time... I completely understand the ownership, but people get the panties all up tight without understand what exactly happened in this case. It's polarizing, and actually still slings mud at times at the current Beavertail owners. But then again, we don't live in a fact-based society.
    Full disclosure, I own a splashed hull and smile ear to ear when I use it.
  18. Capnredfish
    Capnredfish Well-Known Member
    1,072
    422
    938
    I also own and love a splashed B2. However it is not a HB. New @18k with an Etec. Was hard to beat. Only problems are worn out seadeck and a cracked splash well insert. I’m glad splashing or copying is alive and well. Grocery and liquor store would not be a very fun place if it wasn’t.
  19. timogleason
    timogleason I Love microskiff.com!
    204
    83
    153
    Same hull / not splashed. Built by new ownership team
  20. Str8-Six
    541
    435
    188
    Do you know the difference in the cap in each?
