Anything from seaducers to beadchain shrimp/crabs/clousersWhat types of flies are you throwing normally?
So lightly weighted at most? I'd get a bonefish taper then...I like the SA Mastery Bonefish on my 6wt.Anything from seaducers to beadchain shrimp/crabs/clousers
Perfect, thanks for the adviceSo lightly weighted at most? I'd get a bonefish taper then...I like the SA Mastery Bonefish on my 6wt.
DM sentI have a royal Wulff saltwater Bermuda two tone floating line like new $40 shipped, only used once and I sold my 6wt
SA Mastery Bonefish has a long taper for longer shots. Reds many times pop up 15 to 30' out - the head on this line is 40', so that means having 50' of line out of the reel to just get the head out of the rod. Many will have a hard time getting the rod to load quickly for close in shots.Perfect, thanks for the advice
I throw SA amp bonefish on my 8wt H3 for reds without any problemsSA Mastery Bonefish has a long taper for longer shots. Reds many times pop up 15 to 30' out - the head on this line is 40', so that means having 50' of line out of the reel to just get the head out of the rod. Many will have a hard time getting the rod to load quickly for close in shots.
For reds, a shorter, more compact head is better. Flies for reds are larger than what you typically throw for bones. I use the Wulff Bermuda Triangle Taper - standard taper on most reds, but also the Shorts (more compact head) on a 7wt for reds. It's been much easier for people on my boat to load and cast close in with the Shorts lines when conditions call for it.
You raise a good point. Not all fisheries or seasons are the same...SA Mastery Bonefish has a long taper for longer shots. Reds many times pop up 15 to 30' out - the head on this line is 40', so that means having 50' of line out of the reel to just get the head out of the rod. Many will have a hard time getting the rod to load quickly for close in shots.
