1 - 20 of 28 Posts
· Registered
* 2015 SM 1444
* 2nd owner (First only had it for a year)
* 14' length
* 58" Beam
* 2015 20HP Suzuki DF20 (Fuel injected, lean burn, 4 stroke) - Only 59 hours!
* 2016 Karavan aluminum trailer with torsion axles and spare tire
* Minn Kota Edge 45lb thrust trolling motor. (removable) with sealed shaft and salt water anode bolt.
* 19' Carbon Fiber "Loop" push pole
* Upgraded 8 gallon fuel tank
* Micro Power Pole
* JL Audio bluetooth speakers with Subwoofer
*Optima marine battery
*Yeti Cooler
*Custom Seat Cushions for cooler and rear deck
* etc...
I think I covered all of the other options on the boat with the pics, but please feel free to contact me with any questions.
Asking $9500.00
Jacksonville, Florida
9045376148
[email protected]
· Registered
Forgot to mention...
The boat would also come with 3 props. 2 stainless, 1 stock. Plus life jacket, throw cushion, flares, etc... Along with any other extras I might have that I forgot to mention.
· Registered
Nice ride, good price.. GLWS
With a 8gal tank with the Suz 20hp, you must refill only a couple times a year:)
· Ankona Sales Rep
2021 Ankona Advent
Not to derail....where did you get that tach and hour meter and how is it connected to the motor?
· Registered
Hour meter and tach was already installed when I purchased it Shadowcast. So I'm not sure where he bought it. Probably just amazon or something. It's nothing special. The wire from the meter just get wrapped around the spark plug wire about 5 times. There are a few videos on youtube on that.
· Registered
Additional info:
* Boat has always been garage kept
* Flushed after washed after every use
* Only use ethanol free gas
* Recent service to motor:
1. New plugs
2. New thermostat
3. New impeller
4. New fuel filter (in line and in motor)
5. Replaced upper and lower oil
6. Cleaned anodes (still plenty of life)
· Registered
Thanks Stephen. Unfortunately, I won't be in Charleston anytime soon, Chasinreds.
Additional info on boat:
* Pull Start
* Manual tilt/trim
* Nav lights, all around white, LED's to light up control panel, bilge pump, 12v outlet, battery switch.
* Power pole comes with 8.5' spike
* Set up to charge battery from trolling motor plug too.
* Bahamian coins inset into each push pole holder (see pic)
· Registered
Discussion Starter · #17 ·
I put the wooden dowel (used to measure the gas tank) in the PVC pipe. Just didn't like the gas smell or exposed dowel covered in gas in the compartment. The PVC actually worked really well to contain it. Plus it gives me a place to keep the dowel.
Sorry Marsh Pirate...I should clarify that they are not technically bluetooth "speakers". There is a blue tooth unit and AMP that run the speakers. So you have to connect your phone via bluetooth in order to play music.
· Registered
Discussion Starter · #19 ·
I've had a few questions on this, so I figured I would answer on here:
1. It handles smaller chop well. Just planes right over it. However, as you can imagine with any smaller boat that sits low, it doesn't like big chop or large wakes very much.
2. (with just me on board) I've poled this boat into just inches of water. Basically stuck. Even if you are stuck "a little" you can just push it out because it's so light. Awesome boat for any type of skinny water fishing in my opinion.
1 - 20 of 28 Posts
