Is this Kevin? I’ve been to East Cape and Kevin was wonderful and patient. I’m heavy and not mobile And I worried about stability, tippy. An issue? Is yours for sale? Others avail?
Might consider a New Water Ibis as an alternative as that is a little over 21' and drafts pretty shallow with a tunnel that works. Since not poling, thus might fit the bill. They are quite proud of those boats though. Could also look at their Curlew. That Lostmen could also be the right boat. Good to have choices.
thnx for response. I’m working on it. I was thinking Evo or fury for size. Smaller cat (18’ ish) with lower profile?? Two very different things I’m aware. Isis is too much$ for me. Curlew too slow. Picky, picky.Might consider a New Water Ibis as an alternative as that is a little over 21' and drafts pretty shallow with a tunnel that works. Since not poling, thus might fit the bill. They are quite proud of those boats though. Could also look at their Curlew. That Lostmen could also be the right boat. Good to have choices.
Jhw, best pick something before we get oldthnx for response. I’m working on it. I was thinking Evo or fury for size. Smaller cat (18’ ish) with lower profile?? Two very different things I’m aware. Isis is too much$ for me. Curlew too slow. Picky, picky.
956-533-1393Shoot me a message and I'll give you my phone number. I'm down in south padre and I have owned shallow sports, New waters, Pathfnders, Build a few SCB's for shallow sport. I can shoot you right not one boat is good at everything. They all have a give and take. I own a shallow sport 24 V an a Pathfinder 17T
My current primary solo setup is a Majek Texas Skiff, Yamaha 70, jack plate, 80# Minkota, 8' power pole, trim tabs. With this little setup I can fish solo or with the family/friends and be comfortable.
I had an Ultra Cat 22’ very stable and SLOW. THIS WAS B bought the molds. They do not reveal specs?My current primary solo setup is a Majek Texas Skiff, Yamaha 70, jack plate, 80# Minkota, 8' power pole, trim tabs. With this little setup I can fish solo or with the family/friends and be comfortable.
Michael
Michael
Michael
Michael
Michael
My little skiff is the smallest in the Redfish Line and is very stable. Mine is setup to go super skinny and get up in a puddle of mud. I have seen 30mph at WOT one time running the 4 blade deep cupped prop. It drafts less than 6" and I can get on plane in less than 1'. For me it is just this side of perfect but only being 16' long it can beat you up if you try to go too quick through the chop.I had an ultra cat 22’ that was stable but SLOW. THIS WAS BEFORE MAJEK BOUGHT THE MOLDS and they have never given out the specs on their Ultra Cat since... any length? as you’ve seen above I’m solo, fly, catch and release, old, limited movement and value stability and money. I’ll be trolling not polling.
Used East Cape with tunnel or other/tunnel. Lower Laguna Madre SPI so nw to fish then se home. Good weather only. Stability argues for Cat but draft, handling, appearance, etc. argues for skiff.
Thoughts?
