1 - 8 of 8 Posts
Plays with Glass...
Just put my first of 9 coats down. Gave up the idea of controlling dust. However, I would like to hear tips on thinning, brush type, number of coats? Or whatever.
My first mistake was using a microfiber cloth with acetone after the tack cloth. FYI they’re not really lint free.
Premium Member
Real tack cloth & China bristle brush. I thin first coat , go lite w rest. More the the better. You’ll be able to buff out between coats , dust wise. Looking good.
Plays with Glass...
Discussion Starter #3
Thank you! Epiphanes said to thin 50% on the first coat. When I thinned it that far I realized they are thinking most people are using this on bare wood.
Plays with Glass...
Discussion Starter #5
7 coats later this is what I found specific to using Epifanes Gloss over glass/epoxy:
No thinning is needed
No tipping is needed
The foam roller is very important. I found that the ones from wooster labeled "very smooth" vs "smooth surfaces" produce a very spray like finish and self leveling.
Speed when sanding saves paper. If you move to slow the powder gunks up and slows the cutting process down by like 100%
And your advice is spot on about the dust. No reason to worry about it getting in the final product.
Letting this sit for a week before I flip it over to apply bottom paint
If you use a sanding block you will get an amazing finish.
You did a spectacular job on your pirogue.
Reactions: jasonrl23
Plays with Glass...
Discussion Starter #7
Thanks!
Im letting it sit to shrink (Im guessing it will be a month) and will block sand like you said. Its very flat right now so I might start off with 800 or 1000 grit and then buff.
Thanks!
I wanted to give you that info if you did not already know of it.
Great build Jason.
1 - 8 of 8 Posts
