Just upgraded to a new, larger chartplotter and found out the new bracket doesn’t fit the same screw holes, nor does it allow the cables to come through the same hole in the console. What are the best ways to fill these holes (and maybe clean up the holes partially filled in by the previous owner)? I’m new to this side of boat ownership, so I appreciate any direction!
Technology Electrical wiring Wire Electrical supply
To fix it the right way you need to take all those wires out.
Other options would to be fill the holes with epoxy. Buy the little round plastic screw head covers and pop in the hole. Buy a piece of starboard and mount to your console and mount finder to it.
Thanks!
Yes, I plan on removing the wires (and cutting another hole for them, about 3 inches to the right). Just trying to figure out how to fill in the existing holes.
Since that large hole goes all the way through, I can’t just fill it with epoxy. If there’s a normal way to do this, I’m all ears. I don’t love the idea of adding starboard. At the least, I’ll put some tape over it and then the new bracket will cover the holes, but I’d prefer to do it right and repair them.
