SOLD/EXPIRED REDUCED 2009 LT 25 / CC / 30 HP Tohatsu/Minn Kota - NOW $12900
Discussion in 'Sold/Expired Classifieds' started by think7, Aug 8, 2012.
  1. think7
    think7 I Love microskiff.com!
    4
    PRICE REDUCED TO ONLY $12,900
    2009 LT 25, Key Lime green with matching Key Lime green Linex to water line
    Center console with raised front and rear decks, shark eye bow lights, stern light (new 7/12), bilge pump, bow mount nose cap (refinished 6/2012)
    A new 2012 LT 25 as built is now $9533+
    2009 30HP Tohatsu MFS30BEPTS - 158.2 hrs as of 7/5/12 , SS 4 blade prop, 3 (used) spare aluminum props (at least 2 cupped), with tach and water pressure gauge
    2012 version of this motor retails @ $5624.00 + $235 for the tach
    Serviced on 7/5/12 at Tohatsu authorized dealer, new water pump impeller, spark plugs engine oil & filter, Racor filter, lower unit oil, greased, ZERO hours since service
    Humminbird 798 CI SI NVB Side Imaging GPS (just replaced by Johnson Outdoors 6/12), new bracket (6/12)
    Aluminum / SS Continental trailer (upgrade)
    6 gallon tank + 3 gallon Tohatsu spare tank
    Racor water separator
    2 batteries – 2009 Optima Blue Marine deep cycle (155 AH) for engine and Minn Kota,
    2010 – Powersonic 18 AH gel battery for Humminbird
    2009 Dual Pro RS2 12 amp, 2 bank battery charger
    New front pedestal bushing & new rear pedestal base replaced – 7/12
    2 Temptress pro pedestal Butt seats (white) – upholstery refastened with stainless staples (7/12) – front seat differs from jpg below
    Hold My Pole push / anchor pole bracket with 14’ “Pole Cat” pole (repair ferrule and spare Delrin tip) - see image
    Light gray Sea Deck in cockpit and both raised decks - also in bottom and sides of center console storage
    Boat has just been back to Unlimited Glassworks for gelcoat touchups and looks as close as possible to new for a 3 year old boat
    2 x Scotty adjustable angle rod holders with flush mount deck receivers
    3 x SS pop up cleats
    PVC rod holders + custom rod holder extension (PVC, removable with hitch pin) – holds a total of 8 rods on port side of console (see image)
    Insulated cooler / fish box + extra insulation added in lid
    2 x (YES 2) Minn Kota RipTide 55lb iControl, iPilot, 12v motors with 5 remotes, spare props, 60 amp breaker
    Custom made Starboard easy release mount for electric motor (not the Minn Kota quick release) – we carry the spare in the truck – if you need to – the motors can be swapped out in 15 minutes (wired with Posi-lock connectors and mounted on the Starboard mount with SS fasteners)
    Center Console (2) and back hatch/driver’s seat (1) factory cushions
    Sea Sucker mounted holder for pliers etc  (see image)
    Sea Sucker mounted cutting board (see image)
    Includes mushroom anchor with stainless chain, CG approved horn, battery box filled with  numerous spare parts including trolling motor transducer mount for Humminbird and even life jackets if you want them.
    Menhaden dripper  (you can see it in 2 of the port side images)
    Over $21K invested, all invoices available.
    If you want a completely decked out LT 25 at a huge discount – this is it.
    Jeff – 352-322-0990 (cell phone no VM, home 352-489-4998)
    We’re in Dunnellon, FL about 100 miles from either Orlando or Tampa.
    All images are current.
    [​IMG][/b]
