1 - 17 of 17 Posts
Saw some skinny water reds while fishing yesterday and went back today and hooked two fish. First one I had no line left so I trout set it and the hook pulled.... rookie mistake.....
I caught the second one. About 18-19 inches so it was small... BUT a red on the fly is still epic.
I sight fished them off a paddleboard in very skinny water. All of the fish followed the fly for so long before eating.
Hardest part is spotting the fish and making a good cast before you get blown around by the wind. I recently got a small mushroom anchor so I stop running into the problem of getting blown around and spooking the fish. I don't have any good water to pole on a paddle board around me. As long as you find fish and can stay stationary you are set.
Mushroom anchors are a must if you are going the SUP / canoe route.
Keep it between your feet until its time to slip it over the side when you need to stop.
Reactions: Griffinz33
Discussion Starter · #10 ·
I have been trying to figure out a way to quickly set my paddle down to sight cast without making any noise. I always have the problem of having to hold my paddle while casting to a fish. I can’t set it down without it making a loud noise. Any tips?
I found a tip on the internet that worked for me. Tie a loop of rope, just big enough to stick the T of the handle through, to your belt or a belt loop.
When you’re ready to cast, just stick the T through the loop, and let the paddle trail behind you.
When you’re ready to paddle again it’s right there at your hand.
That's pretty much what I do. I have a rubber bungee strap with a loop on one end and a carabiner clip. i rest the paddle foot on the board and then clip it in near my hip, and grab my rod.
1 - 17 of 17 Posts
