1 - 12 of 12 Posts
Hey guys!
I am wanting to know if anyone has a good product or mixture to remove mangrove marks from the boat. Going through tunnels in the glades can be tight and i have not found a good way to get it off.
Thanks!
Barkeeper’s is the way to go... make a small paste with the powder and a bit of water then allow it to sit on the stain until it dries then come back with a soft bush that’s wet and bit more of the cleanser to finish the job. When it’s clean and dry wax the area as noted above.
2018 Ankona Cayenne
Not all magic erasers are the same. Starbrite makes the best of the bunch out there and they’re cheap. I have used it on both smooth surfaces and textured decking with excellent results. Dampen the surface with water and apply liberal amounts of elbow grease. Removing scuffs from smooth fiberglass is where this product shines best, but it will handle most any fiberglass surface without a problem.
Premium Member
Water Recreation Fishing Fish Sound
Vehicle door
We’re talking about the red mangrove scratches, like in the photo, correct?
I was going to thank you guys for the helpful advice on removing them...
but I learned them scratches need to stay on the boat like a badge of honor....because:
“If you’re not banging into shit, you ain’t fishin too hard!”... correct @prinjm6 ?
View attachment 66640 View attachment 66642
Itll buff out
1 - 12 of 12 Posts
