Have antenna that came with boat . Pretty long anttena would like
To leep it and it's cut .. Need to make it longer .. The cable goes into the antenna how don't replace
It with out splicing into it ...
You can lengthen a cable with 2 end and 1 barrel connector.
Probably have to solder the end connectors for good continuity.
Make sure to seal the patch water tight.
Memory says you'll need an SWR meter to tune the signal.
Existing cable - new end connector - barrel connector - new end connector - new cable
