Push pole length?
3.8K views 12 replies 11 participants last post by  bryson
#1 ·
Wanted to get some advice on what length to order a push pole. Fishing grounds will be south Florida and some southwest coast. Flamingo/ENP, Keys and Biscayne will be most commonly fished areas. I have poled several times in the past on other skiffs but never paid attention to the details of the pole. I’m a buy once cry once type so pretty set on a one piece carbon marine.
I’m 6’3 and will be poling an EvoV. Was thinking the 23’. What are your thoughts on that? Or should I consider the 24 or perhaps smaller.
Most of the time will be targeting redfish and snook but I’d like to dabble in the bonefish and tarpon game as well.
Thanks in advance for any advice!
#6 ·
Ha, I thought we were unanimous! Curious why you think the 21? I get the fact that the 24 can be used anywhere I guess my only concern is that the 24 may be overkill for most of the time. I'm not so worried about weight as I'm a pretty big dude but more concerned with practicality. Cost not so much of an issue just want to get the right one for me. Thanks for all the responses so far look forward to more and maybe some reasons for your recommendations.
#9 ·
The standard advice is the length of your skiff, plus three feet for that first pushpole - but these days with taller poling towers I'd say the length of your skiff plus four feet as a starting point. If you're only poling up on the flats that will do just fine... Poling for tarpon is another deal entirely and for that you'll want a 24 foot pole.... Before I added a trolling motor to my old Maverick I did pole in as much as eight feet of water and more when we were working up on tarpon in rivers or out on the deeper edges of flats... With only a 22' pole - that had me down on the deck - not up in the tower until we were almost within casting range...
Longer poles have drawbacks - when trailering - and when working in small creek mouths and other close quarters situations where a longer push pole can be a liability instead of a benefit so give it some thought. Remember as well the longer the pole - the more money it will cost you upfront...
Whatever length you choose, make sure to store that pole, when not in use, out of the sun... UV rays will eventually cause any fiberglass, hybrid, or pure "graphite" or "carbon fiber" (fancy name - more money...) to begin to de-laminate.. so keep it out of the sun at all times when not in use....
"Be a hero... take a kid fishing"
#13 ·
I'll go against the grain a little -- I have a 24 and a 21, and I bring the 21 a lot more often than I expected to. There are definitely times where I like the 24 better, but the 21 rides on the trailer better and is easier to spin overhead for tight maneuvering, especially when fishing creeks.
For where you're fishing, though, you'll probably be happier with the 24. When I head south, that's the one I bring.
