Pros and Cons to restoring/customizing 1991 Johnsen 14'10"
Discussion in 'Boat Yard Basics' started by Carivera, Mar 19, 2017.
  1. Carivera
    Carivera Active Member
    45
    4
    33
    I am torn and need some guidance. I currently have a 1991 Johnsen 14'10" and while I like the boat, I would like to modernize it much like a Native SUV by Ankona. I have decent woodworking skills and fiberglass skills, but have not tackled a project this big. Should I try to take it on, or fish what I have and save up for a Native SUV or something comparable. Does anyone have any insight or past experiences, good, bad or indifferent? Thank you in advance.
  2. yobata
    yobata I Love microskiff.com!
    1,202
    487
    688
    I re-built a 1967 Johnsen 14'. It took a while and that means not as much fishing, but I'm super happy with the results! Good luck
    Carivera likes this.
  3. DuckNut
    DuckNut Brandon, FL
    4,456
    354
    1,938
    As a laymen you will be paying retail for all of your materials and that cost will be high. If you buy a couple gallons of epoxy you will in essence double the cost of your boat and that is before any other expenditures for the re-do. And somewhere you need to include the hours for your labor.
    With that being said and you now a little more aware that you will spend more money in rehabbing the ol' girl than you could ever sell it for - there is so much personal satisfaction in rebuilding your skiff. If you plan and design correctly to what fits your needs and build it properly you will get many years of life out of it and still be thousands of dollars ahead of buying a newer one.
    My personal opinion is that you like the hull and it is nearly the identical hull to the Native so all you are really doing is putting a different cap on it. I say go and breathe new life into her and make it the way you want it.
    Carivera, yobata and State fish rob like this.
  4. WhiteDog70810
    WhiteDog70810 Mostly Harmless
    1,746
    302
    938
    Based on you description, this boat has no serious structural issues and I assume it has a two or three thwart layout. Correct me if I am wrong.
    First question; in your heart of hearts, will you be happy with this boat set up like you imagine it. If you can't absolutely say "yes" without hesitation or doubt, don't risk wasting good fishing time and messing up a good boat. Save up for a boat that fits your needs and fish this one in the meantime.
    If the answer is "yes" or if the boat has any serious problems that you haven't mentioned, you have more skills than most of us had before our first rebuild/build, so jump on in. As stated, you will not increase the value of your boat, so don't think of a rebuild as an investment. Understand that you are only doing this for the fun of it.
    Attempt to keep the rebuild simple and incremental. When the fish are biting, it sucks to have an otherwise good boat turn into a perpetual project because you gutted it in an initial fit of enthusiasm. Break the rebuild into bite-size chunks if possible and always have the goal of getting back on the water ASAP. If necessary, repair big ticket structural items like a rotten transom/rotten stringers/cracked chines first, then get back on the water. Add/repair the sole after that if you want/need to. Later, add a front deck. Eventually add a rear deck. Get to superficial issues like paint and gel coat repairs when you get to them.
    I've seen guys gut small Johnson skiffs and extend them to 16'. That is too much down time IMO unless you have another boat to use in the meantime. If you want a 16' boat, just buy one.
    Nate
  5. DuckNut
    DuckNut Brandon, FL
    4,456
    354
    1,938
    Forget WhiteDog...hop to it! :)
    WD has valid points that I was too lazy to type.
  6. Dadvocate
    Dadvocate If it ain't broke tweak it a little....
    173
    3
    343
    If it is on your bucket list go for it. Fishes one or two people nicely. Adding front and rear decks make these boats fun to fish off. My only complaint is doesn't haul all my camping gear in one trip.:(
  7. Jared T.
    Jared T. I Love microskiff.com!
    84
    6
    83
    I am one of the guys who added 1.5' to the back of the boat, sponsons. Was it a lot of work? YES. Was it worth it? I don't know. It better be. Am I happy I did it? Yes, i believe this boat will perform awesome. I got the hull for free and it is my first rebuild. The boat was in much worse shape than originally thought and I have had to go around and patch a bunch of stupid mistakes made by previous owner which has extended build time. I think the biggest question you need to ask yourself is, do you have enough time or will you make enough time? These things are very time consuming. Half way through I contemplated going to put a down payment on a boat build and cutting my loses with it.
  8. Carivera
    45
    4
    33
    Nothing is wrong with the hull and it wasn't on my bucket list, but after watching youtube videos and seeing the rebuilds on here I think it is now. I don't think i'll be extending it though, though I may want to add a tunnel to it. And I have an idea for a jumpseat with access for a removable 6 gallon tank. I see most of the rebuilds have the walkabale gunnels and I don't see that as a need for me. I'd rather have more room for my boys. I am going to fish the rest of spring and summer, and save up to start late fall and winter, with hopes of being back on the water by next spring.
  9. Shicks007
    Shicks007 I Love microskiff.com!
    73
    12
    83
    My son and I were doing a restomod on a 77 Wenzel. This is essentially the same boat. This has been pretty much 2 years since we started it. I would hazard to guess I have $1500 in materials and countless hours. The project has gone stale at this point and is now for sale. If I had to do it over again, I would not have made it such a big project. I would have done it in phases and tried to keep the phases smaller and more manageable. I certainly enjoy the work, but it takes time, money, weather and space. It's awful hard to get those things to line up when you need them. Just my 2 cents
  10. Carivera
    45
    4
    33
    Did you put a tunnel in it as well? How much do you think you've put into it?
  11. Jared T.
    84
    6
    83
    No tunnel. Don't think it needs one. I don't have the slightest figure on how much money Ive put in it. All materials that have been bought have been shared with many other builds and repairs. Time wise it has taken too long. Mostly because I live an hour away and have to try and sync my schedule with my dads.
Loading...
Similar Threads Forum Date
Pros and cons between salt marsh 14 and shadowcast 16 General Discussion Oct 17, 2016
Pros and cons of four blade prop.s Prop Shop Oct 26, 2015
Galveston - Pros & Cons Gulf Coast, Alabama to Texas Sep 29, 2014
Trolling Motor pros/cons??? General Discussion Nov 18, 2013
Self Bailing Pros/Cons? General Discussion Sep 12, 2013
