1 - 15 of 15 Posts
I have a classic cc with a 15hp 4stroke yamaha. It's currently running with a 9 1/4 x 11 alluminum. When I fish alone I am able to get the rpms up to 5400 and a speed of 21 with an SE200 stabilizer. When I fish with a second person I can't get the rpms over 4900 @ 16mph. I know the SE200 slows me down a little, but how can I gain back those rpms? 9.5x13?
To gain RPM with the prop you are going the wrong way. Lose an inch or two.
I ran the Same motor on a Tiller Classic ...
2 people I Ran the 10.5 ... By myself I could bang the Rev-Limiter ....
But that was a High time Motor ... It Did run pretty Sweet Though ... But I could Hit 24 Mph Though ...
Dave
engine specs:
http://www.yamaha-motor.com/outboard/products/subcatspecs/5/specs.aspx
Specs say the power band is 5000-6000 rpm
You're running 4900 with a heavy load, 5400 with a light load.
You've got everything correct right now.
I wouldn't change anything.
Unless you just feel like spending money.
Yamaha has changed the 15 Hp Used to be the same as the 9.9
I have a 9 pitch as a spare No where near enough prop
engine specs:
She's maxed out? Getting closer to 6000 won't help?
Won &quot;Do More With Less&quot; Award!
Looks like u have a 9 1/4" x 11" pitch "J-1" model that has a wide blade surface that's slow u down some.
U need a 9 1/4" x 10.5" pitch "J" model that has a thinner blade surface and it will gain more RPM and better speed.
I had both on my NMZ with 15hp yami 2-stroke and I like 10.5" (J-model) a lot better than 11" (J-1) model.
It's makes go quicker, faster and good overall performance than 11" wide surface blade.
OEM Yamaha About $65.00
http://www.boats.net/parts/search/Yamaha/Outboard/2003/F15PLHB/parts.html
But ... if you Want the very best Contact the Skiff Shop ....
Dave
1 - 15 of 15 Posts
