I ran a BTX (from what I’ve seen exactly the same as the tailspotter and fly boat works) with an SCB in 12 pitch. 50 Yamaha 2 stroke, Bob's FlatsJac, 33 MPH by myself. It doesn't have trim tabs and never porpoised with that prop (it is stern lifting) It would blow out about 3 inches up on the jack plate.
Now I run an SWC 4 blade in 12 pitch. I’ve touched 34 with it since I can not only jack it up higher but can trim it out more at higher elevations as well. It has a lot more bow rise than the SBC.
I built my own cavitation plate that lets me jack all the way up while maintaining water pressure but I have to be trimmed down a little otherwise it does start to blow out.
Keep in mind your Suzuki has a different gear case ratio and weight than the Yam 2 stroke which may make tweaking the specs a little different, but I’ve had great results with the SWC in general.
pics are of an earlier plate and trimmed out a little more than where I can run it consistently but you get the idea.
