1 - 12 of 12 Posts
Stick with the stock 9.5 x 11P for now. I had mine pitched down to 10P and very mild cupping added...I'm thinking I'm going to wish it was back to 11P. Should get you upper 20s, maybe even 30. I have the same motor and same skiff :)
imo the only way you'll ever be able to dial it in properly is to put a tach on it then adjust pitch from there and go with a stainless if your wallet will allow
Here in Va I found the best prop deals at a local Prop shop. The guy here has been puttin props on boats for years. He matches any internet price on the prop PLUS if the prop does not work you get free adjustments (cup/pitch) till he gets it right, or he will credit the price toward another prop. By far the best way to go. So, I'd look for a good local shop....
thanks for the info I went to a local prop shop bought a prop for a good price and he said if I wasnt happy he would work on it till I was.
What diameter x pitch did you end up going with? Curious considering we have the same boat/motor combo...
I'm running a 9.5 x 10P with light cupping (as stated previously) but I think I'm running a little high in the RPM range. Unfortunately, Tiny Tach sent me the wrong tach and I can't be sure of this until I get my new one in (great customer service). On top of that, the skiff is gone for a couple of weeks for its annual service (wanted to get it done before the Keys trip)... :(
Anyhow...post some more pics of the "Saltbomb"!!!
I dont know much about props but the guy at the prop shop said a 10.25 X 12 would be a good one to start with. He also said he could adjust the size if I didnt like it. what do you think.
I have no idea.  Test 'er out and let me know.  I'm still experimenting with mine. Since my motor is raised so high, I'd probably have to get a prop with that much larger of a diameter heavily cupped.
1 - 12 of 12 Posts
