I currently am running Yamaha 70 HP two stroke on a 16 Sea Chaser Flats and RPM aren't where there should be with my current prop. I want to change it put also am going to be putting a jack plate on.If I reprop it before I install the jack plate will I need to change the prop again after the jack plate is installed?
Thanks Phil
Thanks Phil
