I went to mix a little epoxy today and the pump for the hardener is not giving a full stroke. Every other pump is fine, but the rest are "spits". Looks like I'll be picking up a small digital scale to measure the weights of the epoxy and hardener from now on. Does anyone know the weights of the two, or the ratio's? I'm using West Systems 105 epoxy and 206 hardener.
Thanks.
Don't like pumps for just that reason. Can't trust the mix ratios.
I decided to go with disposable plastic cups for measuring and mixing.
Easy enough to mark a reference cup at 1 oz intervals and mark the mix cup
at the levels needed for a 5:1 ratio.
five parts 105 Resin to one part 206 Hardener
http://www.westsystem.com/ss/206-slow-hardener
B.S.
Brett, Im guessing you got those cups at a paint store? I can't find any that small at Home Depot.
I use the pumps. Got mine at west marine and I've had no issue with them but me being me...I pump into cups then mix. They do seem to be accurate though. I get my cups at the dollar store. I also buy the plastic bowls. Those are good for mixing thickened epoxy (peanut butter thickness) because mixing thick epoxy in the cups causes them to collapse. I also use dollar store measuring cups.
