I've removed all the paint from the hull by sanding it down with a grinder. I coated the hull with a thin coat of poly resin to seal the fiberglass. I need to find out what I should use to smooth out the hull to get it ready to paint.
Here are my thoughts:
1. lightly sand down the hull.
2. coat the hull with a marine bondo.
3. sand down smooth with long board and sandpaper.
4. primer / paint Looking to use a 2 part epoxy paint for the outer hull
Is this how it's done?
What are your thoughts?
Mudd Minnow
Mudd Minnow
