So my 2007 BT has from what I believe is the older 2008 power pole with the manual switch that works fine on the center console, but my controller died. Went to TMS to get my new trolling motor installed in town and got a hold of 2-3 other older mag sync remotes to try and program them to the black receiver box and none worked. Red programming light came on and all, but nothing ever happened. As I said the manual up and down rocker switch works fine though and I know it is all wired inline with each other. This is the programming for the remote I followed with no success:
1. Locate the red light and the small programming button on the receiver board.
2. Push the button and hold for 1 second “the light should stay on solid”.
3. Push any button on one of the transmitters and hold for 1 second
4. Push the same button again and hold for 3 seconds
5. The receiver and transmitter should be programmed to match at this time.
Called Power Pole they think I need a new Mag-Sync unit. Anyone have this issue or a solution before I pull the trigger on a new remote and receiver? Thanks!
