Peenoe fly fishing skiff build
4222 Views 30 Replies 14 Participants Last post by  joaquinarielgarcia19
After a few years of wading and trying to fly fish with my 19’ proline I decided it was time for a skiff. I have almost zero boat building experience so the quality isn’t the best, but as long as it floats and goes where I point it I think I’ll be happy. The base for the build is a 15’ Peenoe. It was produced by a company in Arkansas that build boats for ghenoee for a number of years before branching out on their own. I picked this one up for next to nothing and it came with titles for the hull and trailer. The plan is to add a large front casting deck and a rear deck for a polling platform. I’ll probably go with a 9.9 or 15 hp 2 stroke on the back.
How it started
Motor vehicle Wood Gas Automotive exterior Landscape
Tire Wheel Plant Vehicle Motor vehicle
Drain line and flooring
Boat Naval architecture Boats and boating--Equipment and supplies Wood Automotive exterior
front deck and flooring in place
Stemware Drinkware Tableware Automotive tire Vehicle
1975 9.9 with a 15hp carb, exhaust and reed block
Automotive tire Road surface Automotive exterior Motor vehicle Automotive lighting
my first attempt at gelcoat sucked. It took close to 9 hours of sanding to get it cleaned up to the point where I can try again.
Automotive exterior Motor vehicle Grass Vehicle Shade
bottom paint on and curing
Plant Sky Tree Hood Wood
See less See more
7
Reactions: 2
21 - 31 of 31 Posts
I think I’ve figured out why it was running hot… also closed up a water tube leak that was flooding the exhaust pipe. Runs 10000000x better now.
Automotive tire Wood Bicycle part Automotive wheel system Auto part
Hand Automotive tire Wood Finger Thumb
See less See more
2
Reactions: 1
Painted the rub rails and riveted them in place, patched, painted and mounted the nose cap. Wired the front lights and pulled the wire to the stern. Putting the motor back together tonight. Still need to finish up the access hatches and patch in the rod holders. DMV appointment on Friday to get it registered. If I can get the motor going I may get to take it out for a test run this weekend if the weather cooperates View attachment 199148
Cool project. Looks fishy!
Reactions: 1
Thanks. It’s been fun and I’ve learned a ton so far. Already planning the next build
Always fun to get a new project underway!
Reactions: 1
Haven’t had a ton of time to work on my punch list. Ended up doing a complete backyard tear out and remodel that sucked up several weekends. Did manage to get a few hours with one of my fighting on the water and christened the boat with a few decent jacks and some lady fish. Not what I was shooting for but still a blast to catch. Three of the jacks were caught on a 5wt fly rod and really put up a fight.
Reactions: 1
See less See more
Reactions: 2
Can’t decide. Too big? Found it for $100 on marketplace and could t pass it up.
Plant Sky Land lot Tree Wood
Plant Tree Wheel Boat Wood
See less See more
2
Can’t decide. Too big? Found it for $100 on marketplace and could t pass it up. View attachment 202529
Too tall, maybe you could turn it around so that your not hanging way out past the transom? For $100, you can “customize “ it without too much trouble!
Reactions: 1
That was my thought. I’ll probably cut it at the bottom ladder rung.
Nice boat, I just bought a peenoe. Did you ever patch the sides of the gunwale to the platform where it broke from dropping?
21 - 31 of 31 Posts
