I have the 17T with a 60 hp and this is what I run and why. Started with a 3 blade and boat would run mid 30's, but I wanted to get better hole shot. Guys at Power Tech emailed me the following, "The SCD4R15PYM90 should be the fastest, but the least grippy of my 4-blades and would probably need to run in the lowest, or next to lowest mounting position. The RXB4R14PYM90 should be a bit slower, but have more grip and motor elevation capability, and could probably come up some. The SWW3R14PYM90 should run similarly in speed to the RXB, but have similar, if not more, grip. The SWW4R13PYM90 would have the most grip and motor elevation capability, but would probably be the slowest. I think our range on all props would be from 30-31 to 35-38 (One of my test reports showed a 1700T/C60 that hit 41 with the SCD4R15, but I wasn’t on it, so I think it might be optimistic.)." You prop will be a smaller hub, so your performance will be different, but gives you an idea. The first thing to do is get a Yamaha Tach, installation is pretty simple. That will give you a starting point to determine where your current prop is running at, (RPM). My opinion is that boat runs best with a 4 blade, utilizing the design of the tunnel. The boat does not need a jack plate to run good, although it couldn't hurt. You might be able to move the motor up a few holes on the transom
