Sounds like your motor is not tucked in enough. My 15T has a 50 Yammy but will blow out if i do not trim low enough. You most likely don't have trim on the 25, so you will scrub some speed and bow will be too low in the water if you drop it a notch. IMO if it planes leave it alone, you might feather the throttle to stop blow out.
Bob
