Hi all–– I just bought a used Gheenoe. It has a small hole (less than an inch in diameter) on the bottom of the hull–– close to the drainage port. I'd greatly appreciate any advice on fixing it!
For context, I've never owned a boat, and am usually not the do-it-yourself type when it comes to repairing anything. But, two friends I showed the hole too independently agreed that a do-it-yourself patch job should suffice. So, I figured it would be reasonable to try.
I purchased a fiberglass patch kit from Walmart (attached below) and do have access to a sander and other various tools.
I've been watching YouTube videos and am a little confused in terms of how much to sand away around the hole. For example, one guy says to taper down 4inches around the hole. Another video recommended drilling the hole out with an added taper and patching over that.
Meanwhile, I don't know if the proximity to the drainage port means there are other things I should consider/be careful about?? Also, for what it is worth, I am unable to access the other side of the hole–– I think the hole opens up into the hollow cavity within the hull. I feel like the complicates things. Additionally, the curvature of the area makes me wonder if there is a particular strategy to ensure it lays down right.
Last, I'm not opposed to taking it to a professional–– it just seems like (from what my friends said) I should be able to do this, lol.
Any advice? I probably am overthinking things, but I'd greatly appreciate any guidance/tips.
Thanks everyone!
Nick
Thanks everyone!
Nick
